# PanelView Plus integer input/display with decimal equivalent
**URL:** <https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752>\
**Created:** [July 18, 2014, 10:42am UTC](https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752 "2014-07-18T10:42:02Z")\
**Posts on this page:** 4\
**Author:** ![Curlyandshemp](https://avatars.discourse-cdn.com/v4/letter/c/bcef8e/32.png) [@Curlyandshemp](https://forum.inductiveautomation.com/u/Curlyandshemp)\
**Post date:** [July 18, 2014, 10:42am UTC](https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752/1 "2014-07-18T10:42:02Z")
have an app where I am converting PV+ screens to ignition. Stumped on finding an equivalent for the following Integer numeric input field.
-Processor SLC 5/05
-Input is setpoint for temperature with 1 assumed decimal place
-setpoint is integer N7:40 where value of 362 = 36.2
-PV+ have input field where number is displayed as 36.2 and any changes mantain decimal place
-input of 36.5 would then write value of 365 to N7:40
-if PLC code changes N7:40 to 368, input field would update on PV+ screen as 36.8
I cannot find an equivalent way in Ignition to do this without losing the decimal place.
**Post date:** [July 18, 2014, 12:20pm UTC](https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752/2 "2014-07-18T12:20:20Z")
Good morning!
Just set up a test bed. Seems to work ok.
Set up a tag as a float ant point it to Nx:y(in my case I used N37:29)
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/2X/6/6198287c3022dffa8c006fb649de44690f23949a.png)
Set up linear scaling. The default is already 10:1, so that’s a bonus.
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/2X/0/0abac96acc4a5fde7abf322131ee83e3d32d0ae2.png)
Set up metadata so that it always shows a decimal point. Technically, you don’t need to do this, but it makes it look consistent in the tag browser.
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/2X/3/322e0228c30b38c02d9f1185ed17a240dcd68fc6.png)
Set up Numeric input as Double. Bind Double Value to the Tag. Also, making it Bidirectional will push PLC changes to the display. What I did not show, was to set the Decimal format to always show the decimal ("###0.0") within the field.
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/2X/d/d9b0ece52c47cd6b93a3da91faa6ea51a2c429c7.png)
Hope this helps!
**Post date:** [July 19, 2014, 1:13am UTC](https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752/3 "2014-07-19T01:13:00Z")
Jordan,
thanks for this, really appreciate you going to these lengths.
Will try it out in the AM.
I owe you one
**Post date:** [July 19, 2014, 11:10am UTC](https://forum.inductiveautomation.com/t/panelview-plus-integer-input-display-with-decimal-equivalent/8752/4 "2014-07-19T11:10:19Z")
Tried it this AM and worked like a charm.
thanks for your help.
You should post this solution in the Knowledge Base section, as it is a common seen thing with PanelViews used to input setpoints for older SLCs.
