# Pass tag property to window property
**URL:** <https://forum.inductiveautomation.com/t/pass-tag-property-to-window-property/19943>\
**Created:** [October 3, 2018, 1:08am UTC](https://forum.inductiveautomation.com/t/pass-tag-property-to-window-property/19943 "2018-10-03T01:08:54Z")\
**Author:** ![Andrew\_P](https://avatars.discourse-cdn.com/v4/letter/a/ce73a5/32.png) [@Andrew\_P](https://forum.inductiveautomation.com/u/Andrew_P)\
**Post date:** [October 3, 2018, 11:03am UTC](https://forum.inductiveautomation.com/t/pass-tag-property-to-window-property/19943/2 "2018-10-03T11:03:11Z")
Take a look at this post
> [@Reading UDT Parameter Value?](http://forum.inductiveautomation.com/t/reading-udt-parameter-value/11872):
> Hi All, Is there any ways to read a UDT Parameter value (for example I have a parameter called alarmDescription on UDT tank\_anomaly). I need to be able to read this value into a script. Doing a UDT Binding on a window does not show the parameter values. Or is there a way to read parameter values from the binding? Thank you!
As for the html, just use an expression bound to the text property of the label like:
`"<html>" + {<your string type property>}`
I don't bother with closing html tags anymore unless I need to limit the scope
You can also use the html tag or
to otherwise format text after a html tag for text alignment etc. in addition to the wrapping you get from the "conversion" to html, although it sounds like you might already be familiar with this.
_[View the full topic](https://forum.inductiveautomation.com/t/pass-tag-property-to-window-property/19943)._
