# PDF Viewer Scroll Bar Position
**URL:** <https://forum.inductiveautomation.com/t/pdf-viewer-scroll-bar-position/25739>\
**Tags:** ignition79\
**Created:** [June 11, 2019, 6:50pm UTC](https://forum.inductiveautomation.com/t/pdf-viewer-scroll-bar-position/25739 "2019-06-11T18:50:36Z")\
**Posts on this page:** 3\
**Author:** ![Jmoller](https://avatars.discourse-cdn.com/v4/letter/j/0ea827/32.png) [@Jmoller](https://forum.inductiveautomation.com/u/Jmoller)\
**Post date:** [June 11, 2019, 6:50pm UTC](https://forum.inductiveautomation.com/t/pdf-viewer-scroll-bar-position/25739/1 "2019-06-11T18:50:36Z")
Is there a way to tell if the user has made it to the bottom of a document in the PDF viewer.
**Author:** ![colton](https://avatars.discourse-cdn.com/v4/letter/c/e5b9ba/32.png) [@colton](https://forum.inductiveautomation.com/u/colton)\
**Post date:** [June 11, 2019, 7:25pm UTC](https://forum.inductiveautomation.com/t/pdf-viewer-scroll-bar-position/25739/2 "2019-06-11T19:25:35Z")
The new Perspective module in Ignition 8.0 has this capability but alas in Ignition 7.9 this is not natively possible. If you are trying to display a report, the Report Viewer component also has these capabilities.
**Post date:** [June 11, 2019, 7:43pm UTC](https://forum.inductiveautomation.com/t/pdf-viewer-scroll-bar-position/25739/3 "2019-06-11T19:43:26Z")
You might be able to hack on the Vision PDF viewer sufficiently by accessing underlying objects, but it’s not a trivial process: [PDF Viewer Page Numbers Accessible?](http://forum.inductiveautomation.com/t/pdf-viewer-page-numbers-accessible/18662/2?u=pgriffith)
