# Perspective: How to create a grouped bar chart
**URL:** <https://forum.inductiveautomation.com/t/perspective-how-to-create-a-grouped-bar-chart/38445>\
**Tags:** ignition80, perspective\
**Created:** [September 7, 2020, 7:02am UTC](https://forum.inductiveautomation.com/t/perspective-how-to-create-a-grouped-bar-chart/38445 "2020-09-07T07:02:19Z")\
**Showing post:** 3
**Author:** ![indenkleefj](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/indenkleefj/32/10961_2.png) [@indenkleefj](https://forum.inductiveautomation.com/u/indenkleefj)\
**Post date:** [November 3, 2021, 2:23pm UTC](https://forum.inductiveautomation.com/t/perspective-how-to-create-a-grouped-bar-chart/38445/3 "2021-11-03T14:23:56Z")
I have send a mail to IA support and the response that I got was:
You can “group” the bars together in the bar chart by adding a blank series either side of the series that actually show data, and then setting the values to 0 and setting `hiddenInLegend` to `true` so they do not show up in the legend. You only have to set the values in one set of your data sources, as shown below:
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/3X/7/b/7b32371bdf42dbb09320147454341577886c13c9.png)
Once you add these blank values to your list of series, you should get something that looks like this:
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/3X/d/b/dbf9c67db3fe07df74319e8353c5d470b1f5a774.png)
It’s not exactly like in the example you sent me, but it’s fairly close. If you want to remove the white space between the bars in each group, just change `width` under the `appearance` section for each series.
_[View the full topic](https://forum.inductiveautomation.com/t/perspective-how-to-create-a-grouped-bar-chart/38445)._
