# Perspective - Numeric Input Value Component BUG?
**URL:** <https://forum.inductiveautomation.com/t/perspective-numeric-input-value-component-bug/35908>\
**Created:** [June 23, 2020, 11:41am UTC](https://forum.inductiveautomation.com/t/perspective-numeric-input-value-component-bug/35908 "2020-06-23T11:41:21Z")\
**Showing post:** 5
**Author:** ![dkylep](https://avatars.discourse-cdn.com/v4/letter/d/6de8d8/32.png) [@dkylep](https://forum.inductiveautomation.com/u/dkylep)\
**Post date:** [August 28, 2020, 12:48pm UTC](https://forum.inductiveautomation.com/t/perspective-numeric-input-value-component-bug/35908/5 "2020-08-28T12:48:54Z")
This might help...
> [@CSS pseudo-elements](http://forum.inductiveautomation.com/t/css-pseudo-elements/34953/4):
> It took me a little bit to figure out but it’s actually pretty simple. I just recently downloaded the 8.0.14 nightly (b2020051802) which has the theme updates so the css file structure is a little different. But same concept applies to earlier versions. Basically I created a new css file, lets call it “MyCSS.css” and placed it in the IA perspective themes folder C:\Program Files\Inductive Automation\Ignition\data\modules\com.inductiveautomation.perspective\themes I put my @keyframes into th…
In the linked example I created a 'MyCSS.css' file that is imported into the theme I'm using. If you add
```auto
input::-webkit-outer-spin-button,
input::-webkit-inner-spin-button {
  -webkit-appearance: none;
  padding: 0px 0px;
  margin: 0;
to your css file, all of up/down (spinner) arrows should be hidden. Y
_[View the full topic](https://forum.inductiveautomation.com/t/perspective-numeric-input-value-component-bug/35908)._
