# Perspective Piping - using the wrong width and height?
**URL:** <https://forum.inductiveautomation.com/t/perspective-piping-using-the-wrong-width-and-height/108935>\
**Tags:** perspective\
**Created:** [July 24, 2025, 9:02pm UTC](https://forum.inductiveautomation.com/t/perspective-piping-using-the-wrong-width-and-height/108935 "2025-07-24T21:02:13Z")\
**Author:** ![andrew.budaiev](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/andrew.budaiev/32/72921_2.png) [@andrew.budaiev](https://forum.inductiveautomation.com/u/andrew.budaiev)\
**Post date:** [July 24, 2025, 10:52pm UTC](https://forum.inductiveautomation.com/t/perspective-piping-using-the-wrong-width-and-height/108935/2 "2025-07-24T22:52:51Z")
Could be this
> [@\[BUG 11825\] Embedded Coordinate Container with Pipes Do Not Resize on Page Launch](https://forum.inductiveautomation.com/t/bug-11825-embedded-coordinate-container-with-pipes-do-not-resize-on-page-launch/100831):
> v8.1.43 When you have a coordinate view set to percent with the aspect ratio set to the ratio of the view's size, and you embed a coordinate container that contains pipes (e.g. screenshot) set to percent mode with no aspect ratio (uses the parent view coord container), then when the page loads in the browser, the pipes will not load with the correct size. If you slightly change the size of the browser, it will then resize the pipes correctly. @mperkins This is kind of a major …
_[View the full topic](https://forum.inductiveautomation.com/t/perspective-piping-using-the-wrong-width-and-height/108935)._
