Setting tag history on the UDTs is needed. It’s a setup step, but once it’s done, it’s done. The best way to get an accurate tagBrowserStartPath is to start without it in place and add the first tag to the chart from the folder that you’d like to use as your base. Once added, you’ll want to copy the “Tag Path” value for that tag:
Paste that into the tagBrowserStartPath component property, and remove the value of the tag that you just added (this is the “folder” inside of which the tag resides):
You should now see that the tag browser is displaying tags starting at that path:
