# Perspective XY Chart Circle Bullet Size Not Changing
**URL:** <https://forum.inductiveautomation.com/t/perspective-xy-chart-circle-bullet-size-not-changing/72536>\
**Created:** [April 17, 2023, 5:43pm UTC](https://forum.inductiveautomation.com/t/perspective-xy-chart-circle-bullet-size-not-changing/72536 "2023-04-17T17:43:56Z")\
**Showing post:** 5
**Author:** ![Jonathan\_Bennett](https://avatars.discourse-cdn.com/v4/letter/j/cab0a1/32.png) [@Jonathan\_Bennett](https://forum.inductiveautomation.com/u/Jonathan_Bennett)\
**Post date:** [April 28, 2023, 11:18am UTC](https://forum.inductiveautomation.com/t/perspective-xy-chart-circle-bullet-size-not-changing/72536/5 "2023-04-28T11:18:42Z")
From a previous post, your solution is the only way that I found to change the bullet size, but I started noticing issues with rendering/loading times: [Perspective XYChart Bullet Render Shape](https://forum.inductiveautomation.com/t/perspective-xychart-bullet-render-shape/70237)
I was using that method for awhile (with this symol ●), but noticed a significant slow down in the chart rendering depending on the amount of lines using labels. For example, a chart with all circles was loading in 1 or 2 seconds, but when it had all the lines as labels, it could take 10 or more seconds to render everything. The relationship holds true for using a mixture of circles and labels: more labels = more time.
Since then, I've switch 3 lines to circles, 1 to just a line, and left 2 as rendered labels. But with the big circlular bullets, it can become unreadable.
_[View the full topic](https://forum.inductiveautomation.com/t/perspective-xy-chart-circle-bullet-size-not-changing/72536)._
