# Pipe water pump animation
**URL:** <https://forum.inductiveautomation.com/t/pipe-water-pump-animation/90966>\
**Created:** [May 27, 2024, 5:40pm UTC](https://forum.inductiveautomation.com/t/pipe-water-pump-animation/90966 "2024-05-27T17:40:28Z")\
**Showing post:** 4
**Author:** ![jlandwerlen](https://avatars.discourse-cdn.com/v4/letter/j/bc8723/32.png) [@jlandwerlen](https://forum.inductiveautomation.com/u/jlandwerlen)\
**Post date:** [May 27, 2024, 5:57pm UTC](https://forum.inductiveautomation.com/t/pipe-water-pump-animation/90966/4 "2024-05-27T17:57:22Z")
Don't forget this forum has a good search engine, here's a topic I responded to with an example. It might not be exactly as you need, but should be a good start.
> [@Ignition Perspective Pipe line water flow animation](https://forum.inductiveautomation.com/t/ignition-perspective-pipe-line-water-flow-animation/64212/9):
> Sorry, not sure why I did it that way, but just paste into an opened view. Here is the JSON { "custom": {}, "params": {}, "props": {}, "root": { "children": [ { "meta": { "name": "Line\_1" }, "position": { "height": 220, "width": 386, "x": 156, "y": 208 }, "props": { "elements": [ { "elements": [ { "d": "m21.458 92.737v…
I also recommend a peek at high performance. Your example gives me hives. Your use of color doesn't make any sense and IMO offers nothing positive for the end user.
_[View the full topic](https://forum.inductiveautomation.com/t/pipe-water-pump-animation/90966)._
