Hi
We are having issues with a dropdown in a popup on mobile devices. The labels are displaying but we cannot select the label. We have a live project at the minute an this is causing issues with our client.
I saw that there was another post on this earlier this year but wondering is there any fix for this yet?
I found an open ticket for something similar, but after testing to see what’s going on I found a couple of behaviors that might be of interest:
- While testing on a mobile device I was able to position a dropdown component on the bottom of the screen and use it without issue, so long as
props.search.enabled
wasfalse
. - If
is notfalse
, then “tapping” the dropdown opens the virtual keyboard and moves the dropdown and available labels up. If you then attempt to select a label, your tap actually registers as an attempt to close the virtual keyboard, and since a tap event has been registered (technically not on the dropdown), the dropdown ceases displaying its options.
So, if this sounds like what you are encountering, consider setting Dropdown.props.search.enabled
to a value of false
- this allowed me to use the dropdown as expected.
If this does not sound like what you are seeing, I would need some screenshots of the Dropdown in action or a copy of the View to assist you further.
