# Popup window and Window size and location problem
**URL:** <https://forum.inductiveautomation.com/t/popup-window-and-window-size-and-location-problem/82243>\
**Tags:** ignition81, vision\
**Created:** [November 22, 2023, 10:07am UTC](https://forum.inductiveautomation.com/t/popup-window-and-window-size-and-location-problem/82243 "2023-11-22T10:07:03Z")\
**Showing post:** 27
**Post date:** [November 22, 2023, 3:12pm UTC](https://forum.inductiveautomation.com/t/popup-window-and-window-size-and-location-problem/82243/27 "2023-11-22T15:12:09Z")
To resize it dynamically based on the parent window's session size, you will just have to get the parent window height, create a dimension, and adjust the popup's size. Integrating that into your existing code will look like this:
```auto
from java.awt import Dimension
# Get the parent window
parentWindow = system.gui.getParentWindow(event)
# Get the parent width and height
parentWidth = parentWindow.width
parentHeight = parentWindow.height
# Get and open the popup
popup = system.nav.openWindow('CM/Popup')
# Calculate the desired coordinates for the popup's position
x = parentWidth - popup.width # Far right of Main Window
y = 0 # Top of Main Window
# Position and resize the popup
popup.setLocation(x, y)
popup.setPreferredSize(Dimension(popup.width, parentHeight))
popup.setSize(Dimension(popup.width, parentHeight))
_[View the full topic](https://forum.inductiveautomation.com/t/popup-window-and-window-size-and-location-problem/82243)._
