Power Chart Default Colors With Browse Tags
Can I get some assistance on power chart default colors? When you drag them across they always default to the light colors. I tried doing some settings when it's run in test mode but they do not get saved. Our customer wants to drag over from a list and put them in as required.
Out of all the tags that are being plotted, is there a lot of variance? As in, do the same number of tags get plotted every time or does this vary?
As far as I'm aware, there is no way to change the default colors. There should be a way to accomplish this with scripting, depending on the intricacies of your chart.
Nope not much variance needs to be done. I would think typically 5 - 10 would be the max. I would just want to modify the color on the first say 10 to be a certain color and thickness to cover a typical max.
