# Print Table ontents
**URL:** <https://forum.inductiveautomation.com/t/print-table-ontents/7802>\
**Created:** [January 8, 2014, 12:50pm UTC](https://forum.inductiveautomation.com/t/print-table-ontents/7802 "2014-01-08T12:50:45Z")\
**Posts on this page:** 2\
**Author:** ![ashish007pict](https://avatars.discourse-cdn.com/v4/letter/a/aca169/32.png) [@ashish007pict](https://forum.inductiveautomation.com/u/ashish007pict)\
**Post date:** [January 8, 2014, 12:50pm UTC](https://forum.inductiveautomation.com/t/print-table-ontents/7802/1 "2014-01-08T12:50:45Z")
Hello All,
I am using table component to display the result of SQL Select query. I am getting all the values in Table on Ignition screen when I run application. What I am not able to do is that I am using table.print() funtion to get the hard copy of this table contents.
Below is my code.
[code]
import system
import app
window = system.gui.getWindow(“Current Details”)
table = window.rootContainer.getComponent(“Table”) # Get a reference to the table
#table = event.source.parent.getComponent(“Table”) # Get a reference to the table
#system.dataset.exportExcel("/home/pacrim\_xterm3/Documents/data.xls", 1 , table.data)
table.print()[/code]
This code pops up the Printer Setting window for Printer selection and other Page Setup options.
When I click on Print button in this dialogue box, I just get EMPTY table printed on a paper.
I have attached screen shot of my table contents and my print operation output file.
Can somebody know how to do this?
Ashish
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [April 15, 2014, 10:52pm UTC](https://forum.inductiveautomation.com/t/print-table-ontents/7802/2 "2014-04-15T22:52:11Z")
Sorry for the late response, have you been able to get this to work?
I was able to print the contents of the table with this script
`table = event.source.parent.getComponent('Table')
table.print()`
It looks like you are using the same code. Just a note, I didn’t import anything. If you have not gotten this to work I would consider updating your printer driver. Since you are seeing the printer dialogue box that tells me Ignition is doing what it is supposed to do.
