# Problem result sql query
**URL:** <https://forum.inductiveautomation.com/t/problem-result-sql-query/86345>\
**Created:** [February 26, 2024, 8:52am UTC](https://forum.inductiveautomation.com/t/problem-result-sql-query/86345 "2024-02-26T08:52:39Z")\
**Post date:** [February 26, 2024, 11:13am UTC](https://forum.inductiveautomation.com/t/problem-result-sql-query/86345/2 "2024-02-26T11:13:29Z")
Welcome to the forum, Theo.
See [Wiki - how to post code on this forum](https://forum.inductiveautomation.com/t/wiki-how-to-post-code-on-this-forum/77831). There's a pencil icon below the post so you can edit. You can also use Python's triple quotes to wrap your SQL for readability.
```auto
CodeMat = system.tag.readBlocking(['[default]Cde_Matiere'])[0].value
essai =system.dataset.toDataSet(system.db.runPrepQuery("""
    SELECT DISTINCT CodeStockage
    FROM tStockageInfo
    WHERE CodeMatiere = (?)""",
    [CodeMat])
essai2 = system.dataset.toDataSet(system.db.runQuery("""
    FROM tStockage
    WHERE CodeGroupe=1
      AND NOT CodeStockage IN (
        SELECT CodeStockage FROM tStockageInfo
essai3 = system.dataset.appendDataset(essai2, essai)
The code below won't work.
```auto
    SELECT DISTINCT LibelleL1
    FROM tStockage
    WHERE CodeStockage IN ((?))",
    [essai3]
The prepared query can't take a dataset or even a list.
I think the best solution would be to convert the dataset to a comma separated string using a join function. Then pass that into the IN(\_).
_[View the full topic](https://forum.inductiveautomation.com/t/problem-result-sql-query/86345)._
