# Problem with checking the connection to TCP/IP devices
**URL:** <https://forum.inductiveautomation.com/t/problem-with-checking-the-connection-to-tcp-ip-devices/83605>\
**Tags:** perspective, ignition81\
**Created:** [December 29, 2023, 3:07pm UTC](https://forum.inductiveautomation.com/t/problem-with-checking-the-connection-to-tcp-ip-devices/83605 "2023-12-29T15:07:37Z")\
**Post date:** [December 29, 2023, 3:15pm UTC](https://forum.inductiveautomation.com/t/problem-with-checking-the-connection-to-tcp-ip-devices/83605/2 "2023-12-29T15:15:43Z")
Linux generally constrains non-internet-protocol packets to trusted users and trusted executables. The `ping` executable is one of them. For Ignition to be trusted with ICMP packets, you need to add to its privileges. The simplest solution is with a SystemD service override for `AmbientCapabilities=CAP_NET_RAW`. I recommend this:
> [@Script to ping computer](https://forum.inductiveautomation.com/t/script-to-ping-computer/16612/19):
> Here is a lengthy recap of the steps that lead to success in using java.net (InetAddress, isReachable) on a Linux server (Ubuntu 20.04.5 LTS) with Ignition running as a non-root system user account. Ran this command... sudo systemctl edit Ignition-Gateway.service Added this text... then saved changes. [Service] AmbientCapabilities=CAP\_NET\_RAW CAP\_NET\_BIND\_SERVICE Restarted the Ignition gateway... sudo /usr/local/bin/ignition/gwcmd.sh -r Confirmed the service was running without err…
{Note that `CAP_NET_BIND_SERVICE` is what allows a non-root process to use ports 80 and 443, if you are so inclined.}
If you are using Docker, the IA image doesn't use SystemD. See this topic:
> [@Docker image now defaults to non-root user](https://forum.inductiveautomation.com/t/docker-image-now-defaults-to-non-root-user/69784/5):
> I should clarify that the Docker image launches that gateway directly, no systemd involved (as is typical in most container images). The capabilities that a container gets when launched is controlled by the container runtime--see some info [here](https://docs.docker.com/engine/security/#linux-kernel-capabilities). There isn't a way to "request" default capabilities within the OCI image definition that I'm aware of.
_[View the full topic](https://forum.inductiveautomation.com/t/problem-with-checking-the-connection-to-tcp-ip-devices/83605)._
