# Problems with mobile
**URL:** <https://forum.inductiveautomation.com/t/problems-with-mobile/7821>\
**Created:** [January 13, 2014, 2:06pm UTC](https://forum.inductiveautomation.com/t/problems-with-mobile/7821 "2014-01-13T14:06:25Z")\
**Posts on this page:** 4\
**Author:** ![max7184](https://avatars.discourse-cdn.com/v4/letter/m/aeb1de/32.png) [@max7184](https://forum.inductiveautomation.com/u/max7184)\
**Post date:** [January 13, 2014, 2:06pm UTC](https://forum.inductiveautomation.com/t/problems-with-mobile/7821/1 "2014-01-13T14:06:25Z")
hi at all!!!
2 questions:
1. is there any way to have visible confirm when i press a button, while i’m waiting that the new page launched will run?
2. when i launch my project on a mobile… i have to restart it 4-5 times for a correct use…
the error is always this:
[code]
Time	Logger	Message
(I) 15.01.52 ClientVM Client vm d609d517-641b-0351-aa08-617738d9431f closed: Web session closed.
WARN 14.59.24 ClockDriftDetector Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 14:59:22 CET 2014 currentTime=Mon Jan 13 14:59:24 CET 2014 deviation from expected 1000ms delta=1405ms.
(I) 14.59.14 Projects$ProjectChangeMonitor Starting up client project monitor. project=HMI\_SCADA, uuid=bd1868d5-6255-fa07-6963-c786732cca8d, editCount=3271, scope=4, version=Published
(I) 14.58.54 VMManager VMCreator starting 1 new client VMs.
(I) 14.58.49 VMManager VMCreator starting 1 new client VMs.
WARN 14.58.47 DataServlet Failure in mobiledata/initvm
java.net.SocketException: Connection reset by peer: socket write error
more
(I) 14.58.47 ClientVM Client vm 0b423894-203c-0042-e912-a80f02d87100 closed: Exception during init message
(I) 14.58.45 VMManager VMCreator starting 1 new client VMs.
WARN 14.58.43 DataServlet Failure in mobiledata/initvm
more
(I) 14.58.43 ClientVM Client vm c120769e-a517-b525-6056-b271aea83bf3 closed: Exception during init message
(I) 14.58.40 VMManager VMCreator starting 1 new client VMs.
WARN 14.58.39 DataServlet Failure in mobiledata/initvm
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at java.io.DataOutputStream.flush(Unknown Source)
at com.inductiveautomation.mobile.gateway.MobileVMManager$ClientVMImpl.sendMessage(MobileVMManager.java:595)
at com.inductiveautomation.mobile.gateway.MobileVMManager.initializeVM(MobileVMManager.java:337)
at com.inductiveautomation.mobile.gateway.servlets.MobileSession.initializeVM(MobileSession.java:384)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet$InitVM.handle(MobileDataServlet.java:835)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doRequest(MobileDataServlet.java:159)
at com.inductiveautomation.mobile.gateway.servlets.MobileDataServlet.doGet(MobileDataServlet.java:108)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:861)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:606)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Unknown Source)[/code]
i have last ignition version, and java 7.45… but this error is in 7.400 too…
 ![:scratch:](https://us1.discourse-cdn.com/inductiveautomation/original/1X/76d1620bec252bfac07050c889ff5a91dc8a9c25.gif ":scratch:") ![:scratch:](https://us1.discourse-cdn.com/inductiveautomation/original/1X/76d1620bec252bfac07050c889ff5a91dc8a9c25.gif ":scratch:") ![:scratch:](https://us1.discourse-cdn.com/inductiveautomation/original/1X/76d1620bec252bfac07050c889ff5a91dc8a9c25.gif ":scratch:") what can i do?
**Post date:** [January 13, 2014, 3:29pm UTC](https://forum.inductiveautomation.com/t/problems-with-mobile/7821/2 "2014-01-13T15:29:49Z")
and this:
 	Time	Logger	Message
WARN	16.26.26	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 16:26:23 CET 2014 currentTime=Mon Jan 13 16:26:26 CET 2014 deviation from expected 1000ms delta=1581ms.
WARN	16.16.58	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 16:16:56 CET 2014 currentTime=Mon Jan 13 16:16:58 CET 2014 deviation from expected 1000ms delta=1344ms.
WARN	15.52.51	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:52:49 CET 2014 currentTime=Mon Jan 13 15:52:51 CET 2014 deviation from expected 1000ms delta=1131ms.
WARN	15.50.11	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:50:09 CET 2014 currentTime=Mon Jan 13 15:50:11 CET 2014 deviation from expected 1000ms delta=1501ms.
WARN	15.27.57	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:27:55 CET 2014 currentTime=Mon Jan 13 15:27:57 CET 2014 deviation from expected 1000ms delta=1190ms.
WARN	15.27.37	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:27:35 CET 2014 currentTime=Mon Jan 13 15:27:37 CET 2014 deviation from expected 1000ms delta=1631ms.
WARN	15.27.30	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:27:28 CET 2014 currentTime=Mon Jan 13 15:27:30 CET 2014 deviation from expected 1000ms delta=1367ms.
WARN	15.27.28	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:27:26 CET 2014 currentTime=Mon Jan 13 15:27:28 CET 2014 deviation from expected 1000ms delta=1239ms.
WARN	15.27.03	ClockDriftDetector	Clock drift, degraded performance, or pause-the-world detected. lastTime=Mon Jan 13 15:27:01 CET 2014 currentTime=Mon Jan 13 15:27:03 CET 2014 deviation from expected 1000ms delta=1303ms.`
but my windows server is synch with the same NTP of the VM … what is the problem?
**Post date:** [January 16, 2014, 5:43pm UTC](https://forum.inductiveautomation.com/t/problems-with-mobile/7821/3 "2014-01-16T17:43:09Z")
any news?
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [April 16, 2014, 5:16pm UTC](https://forum.inductiveautomation.com/t/problems-with-mobile/7821/4 "2014-04-16T17:16:51Z")
What are the specs of the Ignition Gateway Server? To be more specific, how much memory is installed? My initial thought is that you may not have enough memory installed to run the mobile clients. Keep in mind that each mobile client will launch a vm on the Ignition Gateway Server. So the memory needed to run the mobile client is coming from the Ignition Gateway Server.
