# Project properties reset to default
**URL:** <https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065>\
**Created:** [February 26, 2014, 1:00am UTC](https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065 "2014-02-26T01:00:02Z")\
**Posts on this page:** 4\
**Author:** ![iamthebull](https://avatars.discourse-cdn.com/v4/letter/i/58f4c7/32.png) [@iamthebull](https://forum.inductiveautomation.com/u/iamthebull)\
**Post date:** [February 26, 2014, 1:00am UTC](https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065/1 "2014-02-26T01:00:02Z")
I moved my ignition gateway from one PC to another. I made a backup of the original gateway and imported it in the new gateway. I noticed that all the project properties have reset to default. Are those values not stored on backup? Can I retrieve the original project properties and restore to the new gateway?
Ignition ver 7.6.4 on both machines.
**Author:** ![greg.simpson](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/greg.simpson/32/3135_2.png) [@greg.simpson](https://forum.inductiveautomation.com/u/greg.simpson)\
**Post date:** [April 21, 2014, 4:36pm UTC](https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065/2 "2014-04-21T16:36:29Z")
You can retrieve the project properties by doing an export from the designer. You will be prompted with a window to select what you would like to export from the project. Here you can select the project properties. What properties didn’t import?
**Post date:** [April 22, 2014, 5:29pm UTC](https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065/3 "2014-04-22T17:29:14Z")
The client launching and auto login properties did not import. There may have been more but I didn’t take note of all of them.
**Post date:** [April 25, 2014, 6:59pm UTC](https://forum.inductiveautomation.com/t/project-properties-reset-to-default/8065/4 "2014-04-25T18:59:49Z")
I tested this with 7.6.6 and all settings imported. I apologize, I don’t have a 7.6.4 gateway to try this with. Can you update your gateway and see if this resolves the issue. I checked here and do not see where this issue had been reported and fixed internally.
