# Project updates
**URL:** <https://forum.inductiveautomation.com/t/project-updates/14264>\
**Created:** [May 11, 2017, 4:19pm UTC](https://forum.inductiveautomation.com/t/project-updates/14264 "2017-05-11T16:19:19Z")\
**Post date:** [May 11, 2017, 6:42pm UTC](https://forum.inductiveautomation.com/t/project-updates/14264/2 "2017-05-11T18:42:56Z")
If you enable the client console (Help → Diagnostics, or Ctrl + Shift + F7) you should see a message with _some_ indication of what triggered the client update; something like:
`11:39:50.330 [AWT-EventQueue-2] INFO com.inductiveautomation.factorypmi.application.runtime.ClientPanel - Received project change notification: notificationMode=PUSH, updateMessage=ProjectUpdated(editCount=3085, uuid=561196fa-5d3e-bcad-a216-567792d2aa89)`
If you then go to the gateway webpage, then Configure → System → Projects, choose ‘Details’ on your project, you should see edit number from the client update reflected.
 ![](https://us1.discourse-cdn.com/inductiveautomation/original/2X/9/9505b429e3815351d1a3d9a3a77a03c06963504c.png)
If you’re seeing global resources/the ‘global’ project as the source of the changes, then you might have some other user triggering changes by saving a global resource on another designer session. There is a minor issue regarding scoping of these global changes that’s still currently active.
_[View the full topic](https://forum.inductiveautomation.com/t/project-updates/14264)._
