# Property "angle" rotate en Ignition Perspective
**URL:** <https://forum.inductiveautomation.com/t/property-angle-rotate-en-ignition-perspective/93168>\
**Created:** [July 12, 2024, 9:35pm UTC](https://forum.inductiveautomation.com/t/property-angle-rotate-en-ignition-perspective/93168 "2024-07-12T21:35:12Z")\
**Post date:** [July 14, 2024, 1:23am UTC](https://forum.inductiveautomation.com/t/property-angle-rotate-en-ignition-perspective/93168/2 "2024-07-14T01:23:14Z")
There are many ways to accomplish this.
Here is one such example.
> [@Animation for Symbol Factory In Perspective](https://forum.inductiveautomation.com/t/animation-for-symbol-factory-in-perspective/63110/11):
> You can do like @Matthew.gaitan has shown, that will definitely work, however, you can also just piggyback on IA’s own animation class as well. [image] The animation value is: ia\_symbolComponent\_\_animate--rotate linear infinite The transform-origin comes from the center point used in element 4 of the SVG.
_[View the full topic](https://forum.inductiveautomation.com/t/property-angle-rotate-en-ignition-perspective/93168)._
