# Prosys client says: "The condition is not currently shelved"
**URL:** <https://forum.inductiveautomation.com/t/prosys-client-says-the-condition-is-not-currently-shelved/8168>\
**Category:** General Discussion\
**Created:** [March 18, 2014, 4:53pm UTC](https://forum.inductiveautomation.com/t/prosys-client-says-the-condition-is-not-currently-shelved/8168 "2014-03-18T16:53:21Z")\
**Posts on this page:** 2\
**Author:** ![lvboque](https://avatars.discourse-cdn.com/v4/letter/l/9f8e36/32.png) [@lvboque](https://forum.inductiveautomation.com/u/lvboque)\
**Post date:** [March 18, 2014, 4:53pm UTC](https://forum.inductiveautomation.com/t/prosys-client-says-the-condition-is-not-currently-shelved/8168/1 "2014-03-18T16:53:21Z")
Hello,
I can connect/disconnect the Ignition server using Prosys SDK client …
However, when I browse the server address space, I got this error:
" “The condition is not currently shelved.”
What does it means?
Logs:
\*\*\* Connected to: opc.tcp://localhost:4096/ignition\_opc\_ua\_server
\*\*\* Current Node: (ID: i=84)
- Enter x to close client
- Enter 0 to start discovery -
- Enter 1 to connect to server -
- Enter 2 to disconnect from server -
- Enter 3 to browse the server address space -
- Enter 4 to read values -
- Enter 5 to write values -
- Enter 6 to register nodes -
- Enter 7 to unregister nodes -
- Enter 8 to create a subscription -
- Enter 9 to call a method -
- Enter 10 to read history -
3
com.prosysopc.ua.StatusException: Bad\_ConditionNotShelved (0x80D20000) “The condition is not currently shelved.” StatusCode=Bad\_ConditionNotShelved (0x80D20000) “The condition is not currently shelved.”
**Post date:** [March 18, 2014, 4:59pm UTC](https://forum.inductiveautomation.com/t/prosys-client-says-the-condition-is-not-currently-shelved/8168/2 "2014-03-18T16:59:38Z")
This is the StatusCode Ignition’s OPC-UA server uses to indicate the trial period has elapsed… go to the Ignition gateway and reset it.
