# Query help sql date range between grouping 7am to 7am
**URL:** <https://forum.inductiveautomation.com/t/query-help-sql-date-range-between-grouping-7am-to-7am/59315>\
**Created:** [May 6, 2022, 6:33pm UTC](https://forum.inductiveautomation.com/t/query-help-sql-date-range-between-grouping-7am-to-7am/59315 "2022-05-06T18:33:42Z")\
**Showing post:** 13
**Post date:** [May 11, 2022, 10:42am UTC](https://forum.inductiveautomation.com/t/query-help-sql-date-range-between-grouping-7am-to-7am/59315/13 "2022-05-11T10:42:12Z")
At some point you are going to be asked to collect and summarize by rotating shifts with arbitrary rotation patterns. It can get complicated. The following generic solution may help you create the correct joins against your production records:
> [@Script for periodically changing shift time](https://forum.inductiveautomation.com/t/script-for-periodically-changing-shift-time/51058/3):
> Hi Berkay, I like to solve this kind of problem with a smart database, like PostgreSQL, where I can define a pattern and repeat it with table generating functions. I tweaked one of my implementations to serve as an example: create table shift\_schedules (shift\_id serial, shift\_name varchar(255), refdate date, repeat int, tzname varchar(255), primary key (shift\_id)); insert into shift\_schedules (shift\_name, refdate, repeat, tzname) values ('Berkay Cinar 3wk', '2021-07-26', 21, 'America/Ne…
You'll have to tweak it for use with SQL Server.
_[View the full topic](https://forum.inductiveautomation.com/t/query-help-sql-date-range-between-grouping-7am-to-7am/59315)._
