# Remote Web Access via Ignition Perspective App - Ignition Maker 8.0.14
**URL:** <https://forum.inductiveautomation.com/t/remote-web-access-via-ignition-perspective-app-ignition-maker-8-0-14/37096>\
**Category:** Maker\
**Created:** [July 26, 2020, 5:38am UTC](https://forum.inductiveautomation.com/t/remote-web-access-via-ignition-perspective-app-ignition-maker-8-0-14/37096 "2020-07-26T05:38:46Z")\
**Showing post:** 10
**Author:** ![brandon1](https://avatars.discourse-cdn.com/v4/letter/b/ea666f/32.png) [@brandon1](https://forum.inductiveautomation.com/u/brandon1)\
**Post date:** [August 12, 2020, 9:15pm UTC](https://forum.inductiveautomation.com/t/remote-web-access-via-ignition-perspective-app-ignition-maker-8-0-14/37096/10 "2020-08-12T21:15:25Z")
I 100% agree with @pturmel. It took me the better part of a day to get SSL working but it is worth it because security should never be an afterthought when it comes to opening a port into your local network!
Here is my post documenting what I had to do to get Lets Encrypt working. I hope it helps you.
> [@Let's Encrypt SSL Certificate Failing](http://forum.inductiveautomation.com/t/lets-encrypt-ssl-certificate-failing/36317):
> I have been following the previous forum posts and have managed to get through all the steps needed to upload my SSL certificate into the gateway. The problem is when I press the continue button the following error comes up: The following is from the gateway wrapper: INFO | jvm 1 | 2020/07/02 16:24:44 | E [g.SslConfigRoutes] [20:24:44]: Unable to transition to ca-signed certificate state route-group=config, route-path=/ssl/transition/ca-signed-certificate INFO | …
_[View the full topic](https://forum.inductiveautomation.com/t/remote-web-access-via-ignition-perspective-app-ignition-maker-8-0-14/37096)._
