# Row selected problem in Perspective table
**URL:** <https://forum.inductiveautomation.com/t/row-selected-problem-in-perspective-table/100580>\
**Tags:** perspective\
**Created:** [January 8, 2025, 12:31pm UTC](https://forum.inductiveautomation.com/t/row-selected-problem-in-perspective-table/100580 "2025-01-08T12:31:46Z")\
**Post date:** [January 8, 2025, 1:36pm UTC](https://forum.inductiveautomation.com/t/row-selected-problem-in-perspective-table/100580/2 "2025-01-08T13:36:01Z")
The trick is to set `enableRowSelection` to `False`, and have a change script on `selectedRow` looking for `None`, and then changing `enableRowSelection` back to `True`. The code must **not** set `enableRowSelection` to `False` when `selectedRow` is already `None`.
Basically, row selection can only be performed _reliably_ by the client browser. When you disable row selection, that state gets sent to the browser, and **it** clears the selection. When you see that change back in the gateway, you can re-enable row selection.
_[View the full topic](https://forum.inductiveautomation.com/t/row-selected-problem-in-perspective-table/100580)._
