# Run Scripts from Tag Change
**URL:** <https://forum.inductiveautomation.com/t/run-scripts-from-tag-change/34579>\
**Tags:** ignition80, scripting, perspective\
**Created:** [May 8, 2020, 3:21pm UTC](https://forum.inductiveautomation.com/t/run-scripts-from-tag-change/34579 "2020-05-08T15:21:58Z")\
**Post date:** [May 8, 2020, 3:33pm UTC](https://forum.inductiveautomation.com/t/run-scripts-from-tag-change/34579/2 "2020-05-08T15:33:44Z")
> [@m.boog](#):
> tag ‘Value Changed’ event scripts can’t call scripts in the Project Library
Sure they can - set the 'gateway scripting project' in Configure -\> Gateway Settings. Or, as @pturmel will tell you, use project-level gateway tag change scripts over individual tag events.
_[View the full topic](https://forum.inductiveautomation.com/t/run-scripts-from-tag-change/34579)._
