# runUpdateQuery - SQL Insert Into Select - multiple datasources
**URL:** <https://forum.inductiveautomation.com/t/runupdatequery-sql-insert-into-select-multiple-datasources/85046>\
**Tags:** scripting\
**Created:** [January 31, 2024, 7:57pm UTC](https://forum.inductiveautomation.com/t/runupdatequery-sql-insert-into-select-multiple-datasources/85046 "2024-01-31T19:57:53Z")\
**Showing post:** 6
**Post date:** [January 31, 2024, 9:00pm UTC](https://forum.inductiveautomation.com/t/runupdatequery-sql-insert-into-select-multiple-datasources/85046/6 "2024-01-31T21:00:17Z")
If you have a competent DB platform, you might find this topic useful:
> [@Taking a Dataset and Inserting it to a SQL temp table](https://forum.inductiveautomation.com/t/taking-a-dataset-and-inserting-it-to-a-sql-temp-table/83852/4):
> If you were using a competent database (the following is PostgreSQL), you can pass java arrays as arguments, and unnest() them in a FROM clause. For an example, I created a table in my psql forum playground called phrases, to be used in a join. When queried by itself, you get this dataset: "#NAMES" "prefix","suffix" "#TYPES" "str","I" "#ROWS","4" "Hello","1" "Good Bye","2" "Welcome to","3" "Whoa!","4" To go with that, in a custom property named lookups, I created the following unbound datase…
_[View the full topic](https://forum.inductiveautomation.com/t/runupdatequery-sql-insert-into-select-multiple-datasources/85046)._
