# Set Multiple Component Property Bindings at once
**URL:** <https://forum.inductiveautomation.com/t/set-multiple-component-property-bindings-at-once/4825>\
**Created:** [July 16, 2012, 6:28pm UTC](https://forum.inductiveautomation.com/t/set-multiple-component-property-bindings-at-once/4825 "2012-07-16T18:28:53Z")\
**Posts on this page:** 3\
**Author:** ![AlexW](https://avatars.discourse-cdn.com/v4/letter/a/b5a626/32.png) [@AlexW](https://forum.inductiveautomation.com/u/AlexW)\
**Post date:** [July 16, 2012, 6:28pm UTC](https://forum.inductiveautomation.com/t/set-multiple-component-property-bindings-at-once/4825/1 "2012-07-16T18:28:53Z")
I’d like to be able to set multiple components property bindings at the same time.
E.g I have a bunch of lines I want to animate to change colors depending on a condition i.e. pump running etc
Currently I have to set each of the line segments animations separately which is a bit of a pain.
We can set multiple components properties at the same time i,e change all selected components colors to red. But setting all the components properties to the same binding seems to be not allowed.
Appreciate it if you’d consider this.
Cheers
Alex
**Author:** ![DomArmstrong](https://avatars.discourse-cdn.com/v4/letter/d/e495f1/32.png) [@DomArmstrong](https://forum.inductiveautomation.com/u/DomArmstrong)\
**Post date:** [October 25, 2012, 7:48am UTC](https://forum.inductiveautomation.com/t/set-multiple-component-property-bindings-at-once/4825/2 "2012-10-25T07:48:47Z")
Any feedback on this? This definitely needs sorting, we often have a bunch of components that need enable/disable and have to manually copy and paste exactly the same stuff into each component, very annoying.
**Author:** ![nathan](https://avatars.discourse-cdn.com/v4/letter/n/c5a1d2/32.png) [@nathan](https://forum.inductiveautomation.com/u/nathan)\
**Post date:** [October 25, 2012, 8:15am UTC](https://forum.inductiveautomation.com/t/set-multiple-component-property-bindings-at-once/4825/3 "2012-10-25T08:15:29Z")
Try using Styles, then copying/pasting the dataset between components.
[This old video on Styles](http://www.inductiveautomation.com/videos/video/27/3) may help.
