# Shift patterns in schedules configuration
**URL:** <https://forum.inductiveautomation.com/t/shift-patterns-in-schedules-configuration/70157>\
**Created:** [February 22, 2023, 9:16am UTC](https://forum.inductiveautomation.com/t/shift-patterns-in-schedules-configuration/70157 "2023-02-22T09:16:13Z")\
**Post date:** [February 22, 2023, 12:27pm UTC](https://forum.inductiveautomation.com/t/shift-patterns-in-schedules-configuration/70157/2 "2023-02-22T12:27:47Z")
When you have complex patterns, you generally need a complex solution. See this topic for working code that implements a generic solution for _ **any** _ repeating shift schedule:
> [@Script for periodically changing shift time](https://forum.inductiveautomation.com/t/script-for-periodically-changing-shift-time/51058/3):
> Hi Berkay, I like to solve this kind of problem with a smart database, like PostgreSQL, where I can define a pattern and repeat it with table generating functions. I tweaked one of my implementations to serve as an example: create table shift\_schedules (shift\_id serial, shift\_name varchar(255), refdate date, repeat int, tzname varchar(255), primary key (shift\_id)); insert into shift\_schedules (shift\_name, refdate, repeat, tzname) values ('Berkay Cinar 3wk', '2021-07-26', 21, 'America/Ne…
If you aren't using PostgreSQL, you will have to substitute other ways to use table-returning functions. (Good luck with that.)
_[View the full topic](https://forum.inductiveautomation.com/t/shift-patterns-in-schedules-configuration/70157)._
