# Siemens OPC UA Server for WinCC Panel RT Issue
**URL:** <https://forum.inductiveautomation.com/t/siemens-opc-ua-server-for-wincc-panel-rt-issue/83412>\
**Created:** [December 21, 2023, 8:56am UTC](https://forum.inductiveautomation.com/t/siemens-opc-ua-server-for-wincc-panel-rt-issue/83412 "2023-12-21T08:56:54Z")\
**Showing post:** 4
**Post date:** [December 21, 2023, 9:41am UTC](https://forum.inductiveautomation.com/t/siemens-opc-ua-server-for-wincc-panel-rt-issue/83412/4 "2023-12-21T09:41:17Z")
Are there any errors in the Ignition logs? Can you upload them?
I suspect you're running into this same issue based on the capture: [Unable to browse tags using Siemens WinCC v 15 - #13 by Kevin.Herron](https://forum.inductiveautomation.com/t/unable-to-browse-tags-using-siemens-wincc-v-15/32605/13)
_[View the full topic](https://forum.inductiveautomation.com/t/siemens-opc-ua-server-for-wincc-panel-rt-issue/83412)._
