# Snmp-Ignition-Module SNMP v3 Setup
**URL:** <https://forum.inductiveautomation.com/t/snmp-ignition-module-snmp-v3-setup/111151>\
**Category:** 3rd Party Modules\
**Tags:** ignition81, scripting, perspective\
**Created:** [October 2, 2025, 7:40am UTC](https://forum.inductiveautomation.com/t/snmp-ignition-module-snmp-v3-setup/111151 "2025-10-02T07:40:44Z")\
**Showing post:** 4
**Author:** ![andrew.budaiev](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/andrew.budaiev/32/72921_2.png) [@andrew.budaiev](https://forum.inductiveautomation.com/u/andrew.budaiev)\
**Post date:** [October 2, 2025, 7:59am UTC](https://forum.inductiveautomation.com/t/snmp-ignition-module-snmp-v3-setup/111151/4 "2025-10-02T07:59:14Z")
I used the module that someone built here:
> [@SNMP function for Ignition version 8](https://forum.inductiveautomation.com/t/snmp-function-for-ignition-version-8/35167/13):
> [Norcal-SNMP-Driver-signed.modl](https://forum.inductiveautomation.com/uploads/short-url/4OCqAaLakmfsLYstPOT8bwh7T3P.modl) (608.0 KB) I don't know how to do that either, but had one of my other engineers do it for me. See attached. Hopefully this helps.
> [@David\_Stone](#):
> So in the code, it is using the same passphrase for both Auth and Priv.
I think I use the same password for both, I need to check.
_[View the full topic](https://forum.inductiveautomation.com/t/snmp-ignition-module-snmp-v3-setup/111151)._
