# \[SOLVED\] Is my Load Factor on a PLC connection(s) too high?
**URL:** <https://forum.inductiveautomation.com/t/solved-is-my-load-factor-on-a-plc-connection-s-too-high/48058>\
**Created:** [June 22, 2021, 1:33pm UTC](https://forum.inductiveautomation.com/t/solved-is-my-load-factor-on-a-plc-connection-s-too-high/48058 "2021-06-22T13:33:59Z")\
**Showing post:** 13
**Post date:** [June 22, 2021, 5:57pm UTC](https://forum.inductiveautomation.com/t/solved-is-my-load-factor-on-a-plc-connection-s-too-high/48058/13 "2021-06-22T17:57:13Z")
Ahem
> [@Monitoring the device load factor](http://forum.inductiveautomation.com/t/monitoring-the-device-load-factor/17389/9):
> For those not at 8.1.6 yet though, I got this from Travis (modified to be a function). Bonus points if you can tell me how to get the number of tags subscribed to a Device… or how I can find out how to do this using the SDK doco. I couldn’t see the IgnitionGateway class within the javadocs frowning def getDeviceLoadFactor(deviceName): """ Description: Gets the load factors for each Device/PLC and writes these into a dataset tag within each PLC's UDT instances. This function must be …
_[View the full topic](https://forum.inductiveautomation.com/t/solved-is-my-load-factor-on-a-plc-connection-s-too-high/48058)._
