# Spinner Date Option Problem
**URL:** <https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288>\
**Created:** [October 22, 2010, 1:15pm UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288 "2010-10-22T13:15:42Z")\
**Posts on this page:** 5\
**Author:** ![aidamcg](https://avatars.discourse-cdn.com/v4/letter/a/90db22/32.png) [@aidamcg](https://forum.inductiveautomation.com/u/aidamcg)\
**Post date:** [October 22, 2010, 1:15pm UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288/1 "2010-10-22T13:15:42Z")
Hi
I am trying to use the spinner as a way to move up and down a date by a week but it only moves up and down by 1 day. Even if I change to hour it still moves up and down by 1 day. Is there some setting I am not using that is causing this. I know Travis showed it at the training and I am sure it worked correctly.
Aidan
**Author:** ![Travis.Cox](https://avatars.discourse-cdn.com/v4/letter/t/b9bd4f/32.png) [@Travis.Cox](https://forum.inductiveautomation.com/u/Travis.Cox)\
**Post date:** [October 22, 2010, 4:27pm UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288/2 "2010-10-22T16:27:12Z")
You can move up a day, hour minute or second by first putting your cursor in that section and then using the spinner buttons. Even if you have a date step size selected you can override that by moving your cursor.
**Post date:** [October 23, 2010, 1:53pm UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288/3 "2010-10-23T13:53:01Z")
Thanks Travis
**Author:** ![ttuttle387](https://avatars.discourse-cdn.com/v4/letter/t/59ef9b/32.png) [@ttuttle387](https://forum.inductiveautomation.com/u/ttuttle387)\
**Post date:** [April 4, 2011, 12:39am UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288/4 "2011-04-04T00:39:14Z")
I am having problems with the spinner.
I have a spinner with the STEP set to DAY and when I select the Spinner, it always changes the MONTH value. I have even moved the cursor to the DAY and when I press up or down, the Spinner changes the MONTH instead.
I am using the Mobile Module and trying to change a date using a spinner.
It just seams that if the ‘DAY’ step is selected, then the day should be the default.
I am running 2.2.5
**Author:** ![Carl.Gould](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/carl.gould/32/7262_2.png) [@Carl.Gould](https://forum.inductiveautomation.com/u/Carl.Gould)\
**Post date:** [April 29, 2011, 6:46pm UTC](https://forum.inductiveautomation.com/t/spinner-date-option-problem/2288/5 "2011-04-29T18:46:00Z")
This appears to be a bug in Java, where it is misinterpreting no-selection as if the month were selected, rather that using the pre-set step default.
I’ve entered it into our bug database to see if we can find a workaround.
