# SSL/TLS How-to for Active Directory LDAPS User source
**URL:** <https://forum.inductiveautomation.com/t/ssl-tls-how-to-for-active-directory-ldaps-user-source/28235>\
**Created:** [September 13, 2019, 5:45am UTC](https://forum.inductiveautomation.com/t/ssl-tls-how-to-for-active-directory-ldaps-user-source/28235 "2019-09-13T05:45:04Z")\
**Showing post:** 23
**Author:** ![cesrom](https://avatars.discourse-cdn.com/v4/letter/c/ea666f/32.png) [@cesrom](https://forum.inductiveautomation.com/u/cesrom)\
**Post date:** [June 23, 2020, 9:47pm UTC](https://forum.inductiveautomation.com/t/ssl-tls-how-to-for-active-directory-ldaps-user-source/28235/23 "2020-06-23T21:47:32Z")
As both @Kevin.Herron and @ryanjmclaughlin have mentioned, just by dropping the certificate into the `data\certificates\supplemental` folder, and restarting the Gateway did the trick for me.
If that didn’t work for you, maybe you can check the following settings:
- **Primary Domain Controller Port:** I have successfully used both 636 and 3269.
- **Use SSL:** Checked.
- **Security Protocol:** SSL (although Auto worked on a recent 8.0.14 installation).
And to check if the certificate was imported correctly, I ran the following command under the `lib\runtime\jre-win\bin` folder:
This will list all certificates:
`keytool -list -v -keystore ..\lib\security\cacerts`
But to filter the list, you can use the alias which in my case was the file name and extension
`keytool -list -v -keystore ..\lib\security\cacerts -alias file_name.extension`
Just substitue `file_name.extension` with the name of your certificate file.
But this begs the following question.
What happens when the certificate expires and it is replaced? Does dropping the new certificate into the `suplemental` folder and restarting the Gateway will handle it automatically or does one have to delete the certificate from `cacerts` manually?
_[View the full topic](https://forum.inductiveautomation.com/t/ssl-tls-how-to-for-active-directory-ldaps-user-source/28235)._
