# Style Customizer and Templates
**URL:** <https://forum.inductiveautomation.com/t/style-customizer-and-templates/8000>\
**Created:** [February 13, 2014, 5:28pm UTC](https://forum.inductiveautomation.com/t/style-customizer-and-templates/8000 "2014-02-13T17:28:22Z")\
**Posts on this page:** 2\
**Author:** ![marioquark](https://avatars.discourse-cdn.com/v4/letter/m/22d042/32.png) [@marioquark](https://forum.inductiveautomation.com/u/marioquark)\
**Post date:** [February 13, 2014, 5:28pm UTC](https://forum.inductiveautomation.com/t/style-customizer-and-templates/8000/1 "2014-02-13T17:28:22Z")
I make a template with a property called Text (String).
I put it in a window.
I add to the object a new local property called UnstyledText (String).
I open the Style Customizer and program Text to switch on UnstyleText values, producing a new string.
It doesn’t work, I have no changing text.
The same procedure starting from a normal Label (not a template) works.
Any suggestion?
Thank you!
**Author:** ![Paul.Scott](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/paul.scott/32/4578_2.png) [@Paul.Scott](https://forum.inductiveautomation.com/u/Paul.Scott)\
**Post date:** [June 20, 2014, 11:19pm UTC](https://forum.inductiveautomation.com/t/style-customizer-and-templates/8000/2 "2014-06-20T23:19:33Z")
I apologize for a delay in a response. Are you still having trouble with this? Could you maybe show us what you’re trying to do, and elaborate a bit more on what you want the end result to be?
