# Sync Services and remote tag provider Configuration question?
**URL:** <https://forum.inductiveautomation.com/t/sync-services-and-remote-tag-provider-configuration-question/55881>\
**Created:** [February 8, 2022, 7:36pm UTC](https://forum.inductiveautomation.com/t/sync-services-and-remote-tag-provider-configuration-question/55881 "2022-02-08T19:36:57Z")\
**Author:** ![kvane](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kvane/32/22228_2.png) [@kvane](https://forum.inductiveautomation.com/u/kvane)\
**Post date:** [February 9, 2022, 4:52pm UTC](https://forum.inductiveautomation.com/t/sync-services-and-remote-tag-provider-configuration-question/55881/2 "2022-02-09T16:52:11Z")
It sound like the Sync Services configuration may not be correct, or you may not have configured the Service Security on the "Main Gateway."
This thread also covers the most common issues with Sync Services setup:
> [@Please, Can you help me Edge Sync Services with SQL server](https://forum.inductiveautomation.com/t/please-can-you-help-me-edge-sync-services-with-sql-server/40020/4):
> You need to make a gateway network connection to your other gateway (Configure -\> Connections -\> Gateway Network) - that’s where you will enter the remote gateway’s IP. Once you’ve done that, you’ll enter that gateway’s name (not it’s IP address) in the Remote Gateway Name field. You will likely also need to configure ‘Service Security’ on the remote gateway to allow the edge gateway to store history using its history provider. [https://docs.inductiveautomation.com/display/DOC80/Gateway+Network…](https://docs.inductiveautomation.com/display/DOC80/Gateway+Network#GatewayNetwork-SettingUpaGatewayNetworkConnection)
_[View the full topic](https://forum.inductiveautomation.com/t/sync-services-and-remote-tag-provider-configuration-question/55881)._
