system.db.runNamedQuery update returns the statement "did not return a result set"
I am calling a named query with parameters that properly executes the update of an MS SQL row, however it returns the following error: “The statement did not return a result set”
Below is the query call within the Query Editor of a Button Component:
params = {“ID_to_Update” : event.source.parent.getComponent(‘ID_Field’).value,
“itemNameInput” : event.source.parent.getComponent(‘Item_Name_Field’).text,
“inventoryCountInput” : event.source.parent.getComponent(‘Inventory_Count_Field’).value,
“locationInput” : event.source.parent.getComponent(‘Location_Field’).selectedStringValue}
system.db.runNamedQuery(“TestSQL Update”, params)
Below is the Named Query, “TestSQL Update”:
UPDATE TestSQL
SET Item_Name = :itemNameInput, Inventory_Count = :inventoryCountInput, Location = :locationInput
WHERE ID = :ID_to_Update ;
The above executes correctly and updates the database properly but returns the error.
Appreciate any feedback I can get.
In the named query editor, you have to set the query type to Update so the named query execution engine doesn’t expect a return dataset.
Thanks! Worked. Appreciate the help.
