# system.db.runPrepQuery - Argument Syntax
**URL:** <https://forum.inductiveautomation.com/t/system-db-runprepquery-argument-syntax/59408>\
**Tags:** vision\
**Created:** [May 10, 2022, 2:54pm UTC](https://forum.inductiveautomation.com/t/system-db-runprepquery-argument-syntax/59408 "2022-05-10T14:54:53Z")\
**Showing post:** 6
**Post date:** [August 3, 2023, 3:19pm UTC](https://forum.inductiveautomation.com/t/system-db-runprepquery-argument-syntax/59408/6 "2023-08-03T15:19:57Z")
Follow up:
> [@Read/Write and Clear from an Array Tag (integer array)](https://forum.inductiveautomation.com/t/read-write-and-clear-from-an-array-tag-integer-array/74199/5):
> Does it work if you convert the list into a jarray first? v = [0,1,2,3] import jarray from java.lang import Integer v\_arr = jarray.array(v, Integer) To be honest I'm not even sure if array columns are supported or not, but see if this gets you to an error somewhere further.
_[View the full topic](https://forum.inductiveautomation.com/t/system-db-runprepquery-argument-syntax/59408)._
