# system.serial.openSerialPort() problem
**URL:** <https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689>\
**Created:** [December 11, 2013, 10:20am UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689 "2013-12-11T10:20:11Z")\
**Posts on this page:** 19\
**Author:** ![Serhii](https://avatars.discourse-cdn.com/v4/letter/s/df788c/32.png) [@Serhii](https://forum.inductiveautomation.com/u/Serhii)\
**Post date:** [December 11, 2013, 10:20am UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/1 "2013-12-11T10:20:11Z")
Hello! I have some very bad issue with openSerialPort command. COM5 is present on my server. When i am trying to use it in Script Playground:
```auto
system.serial.openSerialPort("COM5")
my Ignition desiner closing.
Another problem with it: when i am using this script on TagChange and iPortOpenCloseCmd set to 1:
[code]sP = system.tag.read(“sPortName”).value
if system.tag.read(“iPortOpenCloseCmd”).value == 1:
system.serial.configureSerialPort(port=sP,
bitRate=system.serial.BIT\_RATE\_9600,
dataBits=system.serial.DATA\_BITS\_8,
handshake=system.serial.HANDSHAKE\_NONE,
hardwareFlowControl=False,
parity=system.serial.PARITY\_NONE,
stopBits=system.serial.STOP\_BITS\_1)
system.tag.writeToTag(‘iAllowPortAccess’, 1)
system.serial.openSerialPort(sP)
else:
system.tag.writeToTag(‘iAllowPortAccess’, 0)
system.serial.closeSerialPort(sP)[/code]
…sPortName is a string value = “COM5”.
…gateway goes to stopped. And Web Server goes stopped too. Helpful only the restarting Ignition Gateway service to launch project.
Also trying in Script Playground use this script:
`system.serial.configureSerialPort(port="COM5",\
bitRate=system.serial.BIT_RATE_9600,\
dataBits=system.serial.DATA_BITS_8,\
handshake=system.serial.HANDSHAKE_NONE,\
hardwareFlowControl=False,\
parity=system.serial.PARITY_NONE,\
stopBits=system.serial.STOP_BITS_1)
system.serial.openSerialPort("COM5")`
…and Ignition goes closing.
## Next step - trying to reinstall client and gateway serial modules. Same result. Please, help. P.S. Windows Server 2008 R2. Ignition 7.6.4, Java 7 x64
BR, Serhii Hlupak.
**Author:** ![Tan4i](https://avatars.discourse-cdn.com/v4/letter/t/f17d59/32.png) [@Tan4i](https://forum.inductiveautomation.com/u/Tan4i)\
**Post date:** [December 11, 2013, 10:52am UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/2 "2013-12-11T10:52:05Z")
btw on Win XP SP3 x86 + ign 7.6.4 + java 1.7.45 where is no problem
**Author:** ![James.Lorenz](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/james.lorenz/32/3290_2.png) [@James.Lorenz](https://forum.inductiveautomation.com/u/James.Lorenz)\
**Post date:** [December 11, 2013, 9:28pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/3 "2013-12-11T21:28:24Z")
This issue is reproducible, I will file a bug ticket to get it fixed.
**Author:** ![KathyApplebaum](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/kathyapplebaum/32/7261_2.png) [@KathyApplebaum](https://forum.inductiveautomation.com/u/KathyApplebaum)\
**Post date:** [January 23, 2014, 6:22pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/4 "2014-01-23T18:22:34Z")
We’ve updated some third party libraries that were causing this issue. The fix will be in 7.6.5-rc3.
**Post date:** [January 23, 2014, 7:35pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/5 "2014-01-23T19:35:42Z")
Hello, when this version goes?
**Post date:** [January 23, 2014, 7:44pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/6 "2014-01-23T19:44:26Z")
I’ll ask QA to update you when they know.
**Post date:** [February 7, 2014, 9:01pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/7 "2014-02-07T21:01:48Z")
The fix will be in 7.6.5-rc3, which comes out around the middle of next week. The serial modules aren’t included in the installer, so be sure to download new versions off the Ignition downloads page when the release comes out.
**Post date:** [February 20, 2014, 9:36am UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/8 "2014-02-20T09:36:13Z")
Hello again. Is problem solved?
**Post date:** [February 20, 2014, 4:19pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/9 "2014-02-20T16:19:34Z")
Yes, this issue was fixed in rc3, which came out a couple of days ago.
**Post date:** [February 20, 2014, 6:55pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/10 "2014-02-20T18:55:38Z")
I am doing test and… the issue was not fixed!
Ignition still crash when i try to open the port ☹
**Post date:** [February 20, 2014, 7:06pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/11 "2014-02-20T19:06:45Z")
Do you have the new serial module as well?
**Post date:** [February 20, 2014, 7:25pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/12 "2014-02-20T19:25:25Z")
Will test tomorrow. But… If the modules not upgrated when the Ignition goes to update? We have the step, when we must to choose “Update installed modules” or “Select, which modules must be installed”. So, when we choose “Update installed modules”, serial module must updating to?
**Post date:** [February 20, 2014, 7:46pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/13 "2014-02-20T19:46:18Z")
The serial modules aren’t included in the installer, as I mentioned in a previous post. You need to get them off the downloads page.
**Post date:** [February 20, 2014, 7:55pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/14 "2014-02-20T19:55:27Z")
Ok, thanks, will try
**Post date:** [February 21, 2014, 10:20am UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/15 "2014-02-21T10:20:53Z")
No, issue still have. I was reinstall serial modules (client and gateway) after downloading from market.
Ignition still crashing after trying to open port.
**Post date:** [February 21, 2014, 3:30pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/16 "2014-02-21T15:30:28Z")
Can you verify for us the versions of the modules that you installed?
If you go to the Gateway, under the Status tab, choose Modules and scroll down to the Serial modules. Copy and paste everything on the line “version” for both modules.
**Post date:** [February 21, 2014, 4:57pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/17 "2014-02-21T16:57:26Z")
The market does not have beta/RC modules, you have to go to the “Early Access” downloads page:
[inductiveautomation.com/down … ition/beta](http://www.inductiveautomation.com/downloads/ignition/beta)
Select “7.6 release candidate” from the dropdown, and make sure you are using this version for each of the modules: 1.6.5.2014021316-rc3.
**Post date:** [February 21, 2014, 5:41pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/18 "2014-02-21T17:41:16Z")
Ok, will try
**Post date:** [February 26, 2014, 6:10pm UTC](https://forum.inductiveautomation.com/t/system-serial-openserialport-problem/7689/19 "2014-02-26T18:10:43Z")
All works fine! Thanks!
