# System.tag.browse() "Error browsing tags through scripting." with relative path
**URL:** <https://forum.inductiveautomation.com/t/system-tag-browse-error-browsing-tags-through-scripting-with-relative-path/114527>\
**Created:** [March 17, 2026, 3:46pm UTC](https://forum.inductiveautomation.com/t/system-tag-browse-error-browsing-tags-through-scripting-with-relative-path/114527 "2026-03-17T15:46:19Z")\
**Showing post:** 4
**Post date:** [March 18, 2026, 12:44pm UTC](https://forum.inductiveautomation.com/t/system-tag-browse-error-browsing-tags-through-scripting-with-relative-path/114527/4 "2026-03-18T12:44:28Z")
> [@CP5\_Informatica](#):
> intermediate solution
That's not a solution to the unbounded operation problem in tag events. You may need to delegate work to a self-managed queue, as described here:
> [@Java concurrent queue for tag change scripts](https://forum.inductiveautomation.com/t/java-concurrent-queue-for-tag-change-scripts/82044):
> Continuing the discussion from [[SOLVED] Are tag Value Changed scripts running asynchronously?](https://forum.inductiveautomation.com/t/solved-are-tag-value-changed-scripts-running-asynchronously/68704/5): We've got code in our standard library that I need to log a value change on a tag and then associate various data points with that value change. The value is located in a UDT, and because this is part of our "standard" library we use for our customers, the number of tags is variable and quite possibly numerous so having a gateway tag event script isn't feasible for this solution. I was reading up on …
You may also want to consider using the [Bulk Script Tag Action](https://www.automation-pros.com/toolkit/doc/actors.html#bulk-script-action) from my Integration Toolkit.
_[View the full topic](https://forum.inductiveautomation.com/t/system-tag-browse-error-browsing-tags-through-scripting-with-relative-path/114527)._
