The code looks like this:
path1 = '[IGN01_default]NL Sep 1/PTXX/'
results = system.tag.browse(path1,{"recursive":True, 'tagType':'AtomicTag'}).results
for result in results:
tag_path1 = str(result['fullPath'])
print tag_path1
is printing '[IGN01_default]NL Sep 1/PTXX/oEU'
instead of '[IGN01_default]NL Sep 1/PTXX/PT01/oEU'
I'm trying to write a script to count the number of tag in the historian.
Please edit your post (using the pencil icon), select the code block and press the </> code formatting button to preserve indents and apply syntax highlighting.
For inline code enclose it in a pair of backticks `` so that you get [IGN01_default]NL Sep 1/PTXX/oEU
I ran your code on my test system:
results = system.tag.browse(path1,{'tagType':'AtomicTag', "recursive":True}).results
print tag_path1
...and it works as expected, so I'm not sure what the issue is.
Perhaps you should try using system.tag,browseHistoricalTags instead.
The documentation shows a getReturnedSize()
method that could be shortcut for what you are trying to do. The docs also provide a recursive function example that could be helpful for your usage case.
