system.tag.queryTagHistory() not returning t_stamp column
I'm scripting a tag history query and want a wide table with AsStored values. I'm expecting a t_stamp column but not getting it. (I am getting a column for each tag defined in the paths list.)
    # Read records for the last two hours.
    startD = system.date.addHours(system.date.now(), -2)
    endD = system.date.addMinutes(system.date.now(), -15)
    # Query the historian.
    ds = system.tag.queryTagHistory(
        paths,
        startDate = startD,
        endDate = endD,
        returnFormat = 'Wide',
        columnNames = colNames,
        ignoreBadQuality = True,
	headers = system.dataset.getColumnHeaders(ds)
	for h in headers:
		print h
Can anyone spot my error? Am I missing a parameter?
What's colNames defined as/what result do you get if you omit that parameter?
You do know that you get repeated data when you combine these? It’s a “best effort” format that simply cannot be “good”.
Consider using tall format and then use my groupBy() to obtain the per-tag timestamp/value combinations.
Thanks, Paul.
  • Omitting columnNames = colNames returns the t_stamp column.
  • Adding t_stamp to the colNames list also solves the problem.
I'll investigate further.
Thanks, Phil. Yes, I am aware of that. Your toolkit is installed on this gateway so I can try the groupBy() function.
I bet columnNames just has to be len(tagPaths) + 1 in size with Wide return format.
This sounds familiar, actually... like maybe there is/was a bug in this area a long time ago.
Phil, I'm generating the wide table in a gateway scheduled event. I don't think I can use the groupBy() function is this case. Isn't it expression language only?
Correct. You’d have to script the equivalent. (Highly recommended.)
