[feature-14725]Tabbing between fields in Perspective
Is there a way to set up the tabbing order between fields in perspective views? I’m setting up things that are somewhat like forms and tabbing between fields doesn’t behave as expected. I haven’t been able to find any options related to this so I have a feeling it’s not currently possible.
This would be governed by the tabindex html attribute, but we don’t directly expose that anywhere. I’ll file a ticket to add it as a supported meta prop, which would allow you to add it to any component.
I’ve noticed most input type components seem to tab through according to their z-order. You could try that until the tabIndex property is exposed.
I have a similar need.
Has this been added to any future updates?
I do not believe it has be as of 8.0.12.
Thanks!
No, this hasn’t yet been added. We’ll update this thread once it has.
Following
Following
Following
Psst! Y’all can just click the dropdown at the bottom of the topic to change “Normal” to “Watching”. No need to post a comment to get notifications.
