# Tag Change Scripts stop working
**URL:** <https://forum.inductiveautomation.com/t/tag-change-scripts-stop-working/84819>\
**Created:** [January 26, 2024, 4:25pm UTC](https://forum.inductiveautomation.com/t/tag-change-scripts-stop-working/84819 "2024-01-26T16:25:45Z")\
**Showing post:** 7
**Post date:** [March 20, 2026, 12:15am UTC](https://forum.inductiveautomation.com/t/tag-change-scripts-stop-working/84819/7 "2026-03-20T00:15:12Z")
Making new threads is a heavy operation and busy tags can spawn thousands of threads before they make a difference. See this topic for better solutions:
> [@Java concurrent queue for tag change scripts](https://forum.inductiveautomation.com/t/java-concurrent-queue-for-tag-change-scripts/82044):
> Continuing the discussion from [[SOLVED] Are tag Value Changed scripts running asynchronously?](https://forum.inductiveautomation.com/t/solved-are-tag-value-changed-scripts-running-asynchronously/68704/5): We've got code in our standard library that I need to log a value change on a tag and then associate various data points with that value change. The value is located in a UDT, and because this is part of our "standard" library we use for our customers, the number of tags is variable and quite possibly numerous so having a gateway tag event script isn't feasible for this solution. I was reading up on …
(See all the cross-referenced topics, too.)
Mind you, these are not **simpler** solutions. Sorry.
_[View the full topic](https://forum.inductiveautomation.com/t/tag-change-scripts-stop-working/84819)._
