I am running 7.5.9 on a CentOS Linux box.
I previously was runing 7.5.8 and the Property Binding: Root Container.Status Chart dialog returned Historical Tags to select from when Tag History is selected. Then you would just drag and drop into Selected Historical Tags.
After upgrading 7.5.9, this is broken. No Historical Tags show up in the list of Available Historical Tags.
7.5.8 had issues with Gateway connections dropping out, that seems to be fixed in 7.5.9 but now there is this bug.
Reverting to 7.5.8 again allows the dialog to work, but the Gateway connection issue is there again.
We were able to add the necessary Historical Tags to the Status Chart.
Going back to 7.5.9 fixes the connection issus, but Historical Tag issue is there again.
The projects on the Gateway all work properly. They store the Tag History correctly, and execute the Status Charts correctly.
The issue only appears in Designer. It happens in any component that accesses the Tag History system. Admin privaleges does not fix the problem.
How soon is 7.5.10 or 7.6.3 coming out?
Can I downgrade just the Vision module? Is Designer part of that?
Need answers.
Dennis
