# Tags related changes from Ignition 7.9 to 8.1
**URL:** <https://forum.inductiveautomation.com/t/tags-related-changes-from-ignition-7-9-to-8-1/55587>\
**Tags:** ignition79, ignition80, ignition81\
**Created:** [February 1, 2022, 7:35am UTC](https://forum.inductiveautomation.com/t/tags-related-changes-from-ignition-7-9-to-8-1/55587 "2022-02-01T07:35:41Z")\
**Post date:** [February 1, 2022, 4:49pm UTC](https://forum.inductiveautomation.com/t/tags-related-changes-from-ignition-7-9-to-8-1/55587/2 "2022-02-01T16:49:07Z")
(I’m not an expert in either the old or the new tag system)
You will hopefully be able to switch to the new `ManagedTagProvider` concept; it’s a simpler scaffolding that helps with setting up the basic idea of “Java code that provides Ignition tags”.
I’d start from the SDK example and work from there:
> **[ignition-sdk-examples/managed-tag-provider at master ·...](https://github.com/inductiveautomation/ignition-sdk-examples/tree/master/managed-tag-provider)**
As a general rule: Anything under the `sqltags` package is deprecated or outright removed.
_[View the full topic](https://forum.inductiveautomation.com/t/tags-related-changes-from-ignition-7-9-to-8-1/55587)._
