# Template Repeater & propertyChange events
**URL:** <https://forum.inductiveautomation.com/t/template-repeater-propertychange-events/8948>\
**Created:** [August 22, 2014, 6:56pm UTC](https://forum.inductiveautomation.com/t/template-repeater-propertychange-events/8948 "2014-08-22T18:56:08Z")\
**Posts on this page:** 1\
**Author:** ![cbabb](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/cbabb/32/49029_2.png) [@cbabb](https://forum.inductiveautomation.com/u/cbabb)\
**Post date:** [August 22, 2014, 6:56pm UTC](https://forum.inductiveautomation.com/t/template-repeater-propertychange-events/8948/1 "2014-08-22T18:56:08Z")
I have a project that uses 50 copies of the same template… It’s a perfect application for the template repeater but I’m not sure how to get one portion of it working properly.
Right now, I have a custom property on each template that I tie to a common field on the main screen that changes when I need to fire the propertyChange event on the template. This repopulates the templates with some data.
The question is, how can I do this as easily with the repeater? I see that I have a dataset to work with in the repeater, but that makes it look like I’d have to run a script to build a dataset of triggers to make this happen… not nearly as easy as what I am currently doing…
Any thoughts?
