# Template with Parameter for OPC UDT...getting errors, need help please
**URL:** <https://forum.inductiveautomation.com/t/template-with-parameter-for-opc-udt-getting-errors-need-help-please/46861>\
**Created:** [May 18, 2021, 9:26pm UTC](https://forum.inductiveautomation.com/t/template-with-parameter-for-opc-udt-getting-errors-need-help-please/46861 "2021-05-18T21:26:54Z")\
**Showing post:** 6
**Author:** ![jespinmartin1](https://sea1.discourse-cdn.com/inductiveautomation/user_avatar/forum.inductiveautomation.com/jespinmartin1/32/57175_2.png) [@jespinmartin1](https://forum.inductiveautomation.com/u/jespinmartin1)\
**Post date:** [May 19, 2021, 7:23pm UTC](https://forum.inductiveautomation.com/t/template-with-parameter-for-opc-udt-getting-errors-need-help-please/46861/6 "2021-05-19T19:23:08Z")
Oh no, you miss understood this part
> [@jespinmartin1](#):
> delete al inside [provider] including and save
You should NOT delete this on the template itself, but on the template used as an instance on a window YES.
I encourage to start with indirect tag bindings first to understand the concept and the jump to user defined parameters.
Also it looks like your are doing a bad binding type at the template, when you are using user defined you should you **property binding** , like this:
 ![image](https://us1.discourse-cdn.com/inductiveautomation/original/3X/0/9/095e1b460057ea13e2ae78feedc0ee51884aca27.png)
About Designer Cache:
> [@Launch Error Occurred](https://forum.inductiveautomation.com/t/launch-error-occurred/43807/5):
> Try deleting the cached runtime at `C:\Users\Ross Dye\.ignition\cache\resources\runtimes\11.0.9`. A relaunch should download it
But I think is totally unnecessary in this case since I think your missing a step somewhere.
_[View the full topic](https://forum.inductiveautomation.com/t/template-with-parameter-for-opc-udt-getting-errors-need-help-please/46861)._
