# Text Field, Check box in Flex Container Padding Issue
**URL:** <https://forum.inductiveautomation.com/t/text-field-check-box-in-flex-container-padding-issue/84476>\
**Tags:** perspective\
**Created:** [January 18, 2024, 10:09pm UTC](https://forum.inductiveautomation.com/t/text-field-check-box-in-flex-container-padding-issue/84476 "2024-01-18T22:09:15Z")\
**Showing post:** 6
**Post date:** [January 19, 2024, 8:04am UTC](https://forum.inductiveautomation.com/t/text-field-check-box-in-flex-container-padding-issue/84476/6 "2024-01-19T08:04:11Z")
Deja vu?
> [@How to set Java (Designer) to use 100% screen scaling without changing Windows setting?](https://forum.inductiveautomation.com/t/how-to-set-java-designer-to-use-100-screen-scaling-without-changing-windows-setting/59024):
> I think I saw this mentioned on the forums somewhere about a java argument you can set for this, but can’t find it… Windows screen scaling of anything but 100% causes issues with object displays in Java apps, the Designer included, and while I always have this at 100% (even on my tiny 27" 4K monitor :D), some colleagues aren’t so adventurous and would like to set Windows to 125%. From memory it might have been @Kevin.Herron that mentioned the Java arg?
_[View the full topic](https://forum.inductiveautomation.com/t/text-field-check-box-in-flex-container-padding-issue/84476)._
