# Trend Edge tags on central Ignition gateway
**URL:** <https://forum.inductiveautomation.com/t/trend-edge-tags-on-central-ignition-gateway/57091>\
**Tags:** ignition81\
**Created:** [March 11, 2022, 2:26am UTC](https://forum.inductiveautomation.com/t/trend-edge-tags-on-central-ignition-gateway/57091 "2022-03-11T02:26:42Z")\
**Author:** ![josborn](https://avatars.discourse-cdn.com/v4/letter/j/4bbf92/32.png) [@josborn](https://forum.inductiveautomation.com/u/josborn)\
**Post date:** [March 11, 2022, 2:45am UTC](https://forum.inductiveautomation.com/t/trend-edge-tags-on-central-ignition-gateway/57091/2 "2022-03-11T02:45:55Z")
Some good info on the topic:
> [@Ignition Edge data logging to Ignition](https://forum.inductiveautomation.com/t/ignition-edge-data-logging-to-ignition/15452/2):
> Disclaimer: we haven’t done anything with Ignition Edge in production yet. But you should probably check out the difference between “Edge Panel” and “Edge Enterprise”. See [https://inductiveautomation.com/whats-new-ignition-edge](https://inductiveautomation.com/whats-new-ignition-edge) On “Edge Enterprise”, the edge device connects with a regular gateway, and can sync data using the store-and-forward as usual in Ignition. So it doesn’t act as a plain OPC server, but is tightly integrated.
> [@Please, Can you help me Edge Sync Services with SQL server](https://forum.inductiveautomation.com/t/please-can-you-help-me-edge-sync-services-with-sql-server/40020/4):
> You need to make a gateway network connection to your other gateway (Configure -\> Connections -\> Gateway Network) - that’s where you will enter the remote gateway’s IP. Once you’ve done that, you’ll enter that gateway’s name (not it’s IP address) in the Remote Gateway Name field. You will likely also need to configure ‘Service Security’ on the remote gateway to allow the edge gateway to store history using its history provider. [https://docs.inductiveautomation.com/display/DOC80/Gateway+Network…](https://docs.inductiveautomation.com/display/DOC80/Gateway+Network#GatewayNetwork-SettingUpaGatewayNetworkConnection)
_[View the full topic](https://forum.inductiveautomation.com/t/trend-edge-tags-on-central-ignition-gateway/57091)._
