# Trouble with 'if' statement, button event
**URL:** <https://forum.inductiveautomation.com/t/trouble-with-if-statement-button-event/76892>\
**Tags:** perspective\
**Created:** [July 25, 2023, 5:49pm UTC](https://forum.inductiveautomation.com/t/trouble-with-if-statement-button-event/76892 "2023-07-25T17:49:50Z")\
**Showing post:** 5
**Post date:** [July 25, 2023, 7:32pm UTC](https://forum.inductiveautomation.com/t/trouble-with-if-statement-button-event/76892/5 "2023-07-25T19:32:10Z")
I don't know what's going on with the parameter problem but I offer the following to reduce your code and the brittleness of your project.
1. On the view create a custom property object with structure something like this:
```auto
dataLeft
    desc :
    notes :
    classification :
    category :
    stocked :
    review :
    shortDesc :
1. Bind each of the respective `coord_Left` components to the custom object and make the bindings bi-directional.
2. Now the first block of seven lines of your code becomes,
```auto
dataLeft = self.view.custom.dataLeft
1. Create a second custom property object, `dataRight`.
2. Generate the `coord_Right` components using:
```auto
dataRight = {}
dataRight["Item ID"] = item_id
dataRight["Category"] = str(dataLeft["category"])
dataRight["Class"] = str(dataLeft["classification"])
dataRight["Desc"] = desc[quote="mdemaris, post:3, topic:76892"] # What's going on here?
dataRight["Short"] = dataLeft["shortDesc"]
dataRight["Stocked"] = str(dataLeft["stocked"])
self.view.custom.dataRight = dataRight
1. Bind all the coord\_Right components to the custom parameter object members.
I suspect that most of this routine could be eliminated by disabling the button that calls this event until all the relevant fields have been filled out. Show a red `*` or icon beside each field until it's got a legitimate value and provide a tooltip on the icon to indicate what the problem is.
_[View the full topic](https://forum.inductiveautomation.com/t/trouble-with-if-statement-button-event/76892)._
