# Understanding Synchronization and Data Access with system.util.getGlobals
**URL:** <https://forum.inductiveautomation.com/t/understanding-synchronization-and-data-access-with-system-util-getglobals/86019>\
**Created:** [February 20, 2024, 2:44pm UTC](https://forum.inductiveautomation.com/t/understanding-synchronization-and-data-access-with-system-util-getglobals/86019 "2024-02-20T14:44:55Z")\
**Showing post:** 5
**Post date:** [February 20, 2024, 3:05pm UTC](https://forum.inductiveautomation.com/t/understanding-synchronization-and-data-access-with-system-util-getglobals/86019/5 "2024-02-20T15:05:29Z")
You might find this topic helpful, too:
> [@Java concurrent queue for tag change scripts](https://forum.inductiveautomation.com/t/java-concurrent-queue-for-tag-change-scripts/82044):
> Continuing the discussion from [[SOLVED] Are tag Value Changed scripts running asynchronously?](https://forum.inductiveautomation.com/t/solved-are-tag-value-changed-scripts-running-asynchronously/68704/5): We've got code in our standard library that I need to log a value change on a tag and then associate various data points with that value change. The value is located in a UDT, and because this is part of our "standard" library we use for our customers, the number of tags is variable and quite possibly numerous so having a gateway tag event script isn't feasible for this solution. I was reading up on …
_[View the full topic](https://forum.inductiveautomation.com/t/understanding-synchronization-and-data-access-with-system-util-getglobals/86019)._
